It is currently Wed Nov 11, 2026 9:52 pm
 Page 1 of 1 [ 10 posts ]
PostPosted: Sun Jun 25, 2006 9:13 pm
Images: 1
[color=blue][/color]Ive owned this car for 3 years since my father bought it in 1993, it is i need of major repairs now and was when he gave it to me.
any suggestions on the following?
oil pain damaged, needs actual gasket (leaks yes)
rear drums grind metal to metal and currently fail to hold car with cable adjusted to max thread
needs new throttle body due to 3 broken torx bolts
replacement on entire a/c system and heater core
possible rewiring from relays due to some soaked wires and overheated wires
needs new radiator and hoses
work ive done:
replaced axles, rotars, done head gasket work, water and steering pump, internal window mechanisms and minor repair work including front end collision w/ headlight housing, grille, hood, and bumper
any suggestions on future body work such as doors and rear side body?
front fenders seem easy enough to take out and rebolt
other than the major problems (including radio right speaker channel fails to work) this car is a blast to drive
its got amazing acceleration and top fuel economy for its age
i hope to own this car for the rest of my life... which might end inside of it
1988 Cutlass Calais 2.5L
PostPosted: Sun Jun 25, 2006 10:55 pm
Replace the oil pan gasket? (Is there any other gasket besides the actual one?)
This is because the rear drums are supposed to have PADS in them, and the pads will hold the car, not metal to metal contact. You need to replace the brake pads, and more than likely the drums at this point.
If you cant extract the bolts, replace the throttle body.
Is the car worth it?
Soaked wires? Soaked in what? Which relays?
Make this a priority.
They may seem easy to just unbolt and rebolt, but consider you need to remove the whole front end,not just the fenders. There is more to hanging a fender then bolting it up and going. You need to align the panel in 8 directions, and make sure it is just perfect, that is, if you want to do it right. You may as well do the AC, and radiator work while the front end is off, and any other engine work will be easier without the front clip on the car.
The speaker is the least of your problems.
For your sake, I hope not. I have never heard of a iron duke being described as "amazing accelleration".
you have done alot of work on this car, hope it works out for you.
PostPosted: Mon Jun 26, 2006 12:34 am
Hi philosophic, andrewk, hello everyone,
....... This is because the rear drums are supposed to have PADS in them ........
I don't know much about those new fangled machines, but aren't pads used on rotors, and shoes with drums?
Right after the brakes and tires.
philosophic wrote:
........ other than the major problems (including radio right speaker channel fails to work) ........
A speaker that doesn't work, is not going to get anyone killed. Can't say the same for brakes and tires.
PostPosted: Mon Jun 26, 2006 7:51 am
You have no clue what you are talking about... :laughing: :laughing: :tongue:
Thanks for the clairification Norm-
PostPosted: Mon Jun 26, 2006 11:17 pm
........ You have no clue what you are talking about... :laughing: ........
Maybe when I grow up, I can be like andrewk, and I too, can have a "clue".
PostPosted: Tue Jun 27, 2006 7:04 am
:thumbup: :laughing: :laughing: :laughing:
PostPosted: Tue Jun 27, 2006 11:49 am
Images: 1
ok thanks for the flames in my post... how childish
well i replaced the TBI and everything works on that now
next, drums & radiator!
PostPosted: Tue Jun 27, 2006 7:18 pm
No flames here... search 88 coupe or andrewk and you will see it for what it truely is.
PostPosted: Tue Jun 27, 2006 10:19 pm
philosophic wrote:
ok thanks for the flames in my post... how childish ........
Flames?
Did I miss something?
PostPosted: Tue Jun 27, 2006 11:34 pm
Flames?
No, it was just the charcoal for the grill... Good news is that the coals are ready. You want one burger or two? :lol:
