It is currently Sun Nov 08, 2026 4:58 pm
 Page 1 of 1 [ 10 posts ]
 Post subject: Engine problem
PostPosted: Thu Jul 27, 2006 9:24 pm
Latley, my 85' has been runnin a little funny. Every time you open the throttel hard, it blows out alot of carbon (black smoke) from both pipes. I pulled the plugs and cleaned them, but it remained the same. I'm thinking its possibly the mixture and its getting too much gas, but im not a mechanic just an enthusiast. Any ideas?
PostPosted: Thu Jul 27, 2006 9:49 pm
If the plugs were really black after you took them out, it is possible you have over-rich carburetion. Now I'm not 100% sure if you can adjust on a 1985 carburetor (Not really good on the EPA emissions stuff) or it could be many other things to do with the emissions. May also be time to get your carburetor re-built.
 Post subject: Re: Engine problem
PostPosted: Sat Jul 29, 2006 4:53 am
adma449 wrote:
........ but im not a mechanic just an enthusiast. Any ideas?
Take it to someone who is. If its what I think it is, he/she will verify it in three minutes or less, and should have it repaired in about ½ an hour.
PostPosted: Mon Jul 31, 2006 11:41 am
what you thinkin norm? carb kit? ;-)
PostPosted: Mon Jul 31, 2006 11:19 pm
Problem solved. I spent a while looking for a problem, and it ended up being a vacum line that was not connected at the air breather.
PostPosted: Tue Aug 01, 2006 9:46 am
ahh... so the air flapper valve was staying shut, choking the engine. Makes sense! :-)
PostPosted: Wed Aug 02, 2006 2:00 pm
Nope. When done right, a carb rebuild takes a lot more than a ½ hour. 95% or more, of the carbs that have been rebuilt did not need it.
I was thinking of three different carb related problems. One was a different vacuum hose than he discribed.
88delta88 wrote:
........ the air flapper valve was staying shut, choking the engine ........
Nope.
PostPosted: Wed Aug 02, 2006 4:14 pm
[/QUOTE] I was thinking of three different carb related problems. One was a different vacuum hose than he discribed. [QUOTE]
Which hose Norm?
PostPosted: Thu Aug 03, 2006 1:49 am
I suppose what you are saying Norm, is Guess Again ;-)
I dont think he was referring to the PCV line, or valve... Was he?
I said diverter valve because I remember having one vacuum line on the air cleaner of my 84 chev 305, and that was to run the cold air diverter valve during warmup.
PostPosted: Thu Aug 03, 2006 4:22 am
adma449 wrote:
Which hose Norm?
Since it's fixed, it doesn't matter much, does it?
88delta88 wrote:
........ I dont think he was referring to the PCV line, or valve ........
Malfunctioning PCV would not cause black smoke.
........ and that was to run the cold air diverter valve during warmup.
The position of the valve only determines where the air comes from.
