It is currently Sun Nov 08, 2026 3:50 pm
 Posted: Wed Aug 09, 2006 3:48 pm |
if you can feel it shift from 1-2 when you manually move the selector, the trans is not stuck in third. That does not rule out other trans problems, or engine problems for that matter. Need more info. How long has this been happening, and are there any times it is worse or better?
You said you added trans fluid, how low was it, and does it leak?
Do you get a check engine light coming on at all? You havent described the lack of power in any depth. You'll need to explain a little further to get any results.
 Posted: Thu Aug 10, 2006 11:18 pm |
take it to a trans shop, diagnosis should be under $65.00...
 Posted: Sun Aug 13, 2006 6:33 pm |
glad to hear! How did you come across a blown fuse like that?
85cieraholiday
 Posted: Tue Aug 15, 2006 12:14 am |
cracker_syndicate wrote: we figured it out. no transmission solenoid, nothing huge at all. it was just a blown fuse and took 2 minutes to replace. its a little hard to believe but thats all it was, runs great now.
Why cant every repair be that cheep to fix? LOL
_________________ .
