PostPosted: Fri Dec 08, 2006 7:55 pm
Hey guys,
Up until recently, the turn signals in my Custom Cruiser worked fine. They would click into position and blink until you moved them back to the center, or turned far enough.
Now, the right one isn't blinking. I've gone outside and looked at it. The lights light up fine, and the stalk works perfectly, it's just that there's no clicking noise and the lights stay solidly lit (this includes the indicator light on the dash, the tail light, the cornering light, and the parking light)
I was told that it could be a busted relay somewhere. Does anyone have any suggestions on where to look?
PostPosted: Fri Dec 08, 2006 8:36 pm
Check your bulbs, if they are ALL illuminating, go buy a new flasher, they're cheap. On your fuse panel, its the cylindrical-looking module.
Take a look here also: Flashers
PostPosted: Fri Dec 08, 2006 8:50 pm
It could also be that one filiment is burned out. If you use two filiment bulbs (one for parking, one for turning) that could make the flasher not work. A weak ground on one side can also do this. If the left works, shouldnt the right? Since the flasher controls both sides... Unless there are seperate relays in the flasher...
Users browsing this forum: Bing [Bot] and 16 guests
