It is currently Sun Nov 08, 2026 3:08 pm
 Posted: Sun Jan 07, 2007 7:00 pm |
C202 Location
C202 View/Pinout
Turn Signal Diagram (Had to piece that one together, two pages...two little squigglies? on 14 and 15 in middle of page are connected, that's just where it was split)
ggevaert
 Posted: Wed Jan 17, 2007 6:48 pm |
Joined: Thu Nov 02, 2006 3:46 pm Posts: 36 Location: Niagara Falls, Ontario, Canada
Ok, got it narrowed down to the turing signal switch. looks like the corner lights are a part of it in a separate internal circuit.
Can someone please post a steering wheel schematic so I'm not going in blind when I take it apart and replace the switch.
Thank You.
_________________ The G-Man
1991 Dodge Shadow - 4 cyl.
1984 GMC 1500 straight 6.
etc. etc.
 Posted: Wed Jan 17, 2007 7:47 pm |
ggevaert wrote: ........ but what then does not make sense is why only the corner light does not work ........
As you can see in the wiring diagram, there are several contacts in the TS switch.
If the contact that controls the light does not close, power cannot get to the bulb.
