It is currently Fri Nov 20, 2026 12:53 pm
 Post subject: wheel bearings
PostPosted: Sat Jun 05, 2004 12:59 am
my wheel bearings are going out i think. When i turn the wheel there is this god awful squeek. Are the wheel bearings hard to do i know its all one piece i was just wondering if it is something i can do. I have a haynes manual and everything....
PostPosted: Mon Jun 07, 2004 8:07 am
well mine was going out on the front passanger side of the car and i just replaced the hub assembley. i would just do that then all of that shit is new.
Rusty Froman
President and Founder of Simply Irresistible Car Club
http://sicc6.tripod.com
http://www.cardomain.com/memberpage/347561
PostPosted: Wed Jun 09, 2004 7:01 am
usually when a wheel bearing fails the sound is more heavy than a squeak. I would inspect your front discs, see if they are worn and the wear indicator is what you hear squeaking.
PostPosted: Wed Jun 09, 2004 3:09 pm
no its not the brakes they are fine....they squeek not when i am pushing on the brake but when i am driving it is a constant squeek
PostPosted: Wed Jun 09, 2004 8:05 pm
Justin, just because you're not pressing on the brake doesn't mean it couldn't be the brakes themselves. As OldsGuy said, when a wheel bearing or hub assembly begins going bad, it makes more of a drumming or grinding sound, usually more noticeable when turning one direction or another. Squeaking is generally associated with brakes, and the "squeakers" built into the brake pads will often squeak when the brakes are not applied, then will quiet down when the brakes are depressed. In many cases the brakes will squeak if the wheel is turned, usually caused by flex in the brake rotor or the pads squeaking against a rust lip on the edge of the brake rotor. Pull the front wheels and be certain before you blindly go into replacing a hub assembly, just to be sure. Also, in regards to installing the hub assembly yourself, it can be done, although you'll need a spindle nut socket, 1/2" drive torque wrench which can go up to 125-150 ft. lbs, as the axle nut needs to be properly torqued after the hub is installed and the axle nut screwed on, possibly some torx or allen wrenches or sockets depending on the style bolts holding the caliper and caliper mounting bracket, wrenches and/or sockets in the appropriate sizes, and possibly a hammer and chisel to separate the hub assembly from the spindle.
