It is currently Fri Nov 20, 2026 1:51 pm
 Page 1 of 1 [ 9 posts ]
 Post subject: Oil Leaking?
PostPosted: Wed Jun 30, 2004 8:56 pm
Hey all, I have a 1983 Toronado with the 307 in it. I've noticied that oil is seeping out the right side of the engine between the 2 middlie spark plugs. A friend suggested tightening the bolts on the head gasket. I'm not really sure what to do. The car has 63,000 miles on it (original). Any advice is appriciated.
Thanks!
PostPosted: Wed Jun 30, 2004 9:12 pm
These bolts have a certain sequence and torque rating that they are supposed to be tightened down to. Tightening one bolt down too much wouldn't be good. Sounds like your Head Gasket is going bad and you should get that replaced as soon as possible, and don't drive it around to much like that...don't want to end up running your engine dry, with no oil.
PostPosted: Wed Jun 30, 2004 11:38 pm
Are you sure its where the cylinder head meets the block, or is it possibly leaking down from the valve cover? The newer 5 bolt valve covers had notorious problems with valve cover leakage, and with all the smog garbage on the engine, its sometimes difficult to be exact, especially on the right side, with the A/C compressor and everything else there. Just another thought....
PostPosted: Thu Jul 01, 2004 10:11 am
sounds like it's most likely the valve cover gastket... if it was coming from there it could be dripping over where the heads meet the block and possibly look like that's where it's coming from. Replacing a valve cover gastket isn't a big deal, but as Stroker said, if you have alot of smog junk in the way it can make things more complicated.
if your head bolts were so loose that oil was spewing out of there... well... that would be a whole new set of problems, you're engine would probably run bad or not at all if that was the case.
PostPosted: Thu Jul 01, 2004 11:20 am
Here's the third vote for the valve cover gasket...
PostPosted: Thu Jul 01, 2004 11:45 am
That sounds like what I had before I changed my valve cover gasket in March, I would check that 1st, mine was made or cork (or something like that) and it was cracked and falling apart. Wasnt hard to do, and it only cost $6 for the gasket (which for my car also came with the egr valve gasket since u have to remove that anyway to get the valve cover off). The new gasket I got is rubber, so it should last longer then the original.
PostPosted: Thu Jul 01, 2004 12:03 pm
Well.. when it comes to engines.. I'm pretty stupid. My best friend though, is very good with them... I'll let him read it and have him check the valve gasket cover.. I really hope it isn't the head gasket or... this car is probably gonna become a parts car.
Thanks!
Nick
PostPosted: Thu Jul 01, 2004 3:23 pm
Hopefully it is the valve cover gasket... :yes:
PostPosted: Thu Jul 01, 2004 7:15 pm
Hi Nick Hi all,
Poor choice of words. As long as one has the desire and ability to learn, one is not stupid. A better phrase might be "I'm just starting out".
Those cork gaskets tend to dry out, shrink, and then split open over the years causing oil leaks.
I just changed them in my '87 ( first time) and my '70 (who knows, I just bought it a year ago).
With a head gasket you would not be concerned about a leak. :lol:
