It is currently Mon Aug 24, 2026 10:30 pm
 Page 3 of 4 [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Apr 27, 2008 9:42 am
aron115 wrote:
yeah i know it was your point. i brought it up again because i thought it was a valid question and i really wanted to know the answer to. my resonator had water in it. but i dont think it was put there.
You can be sure it wasn't put there intentionally. It was probably condensation of some sort.
PostPosted: Sun Apr 27, 2008 10:02 am
yeah, right now im not the happiest about my car. the check engine light has been coming on and its been idling bad when it comes on..but that is offtopic and i think that should be for another topic. yeah i suppose it could be condensation, would have to be. or watery gas heh
PostPosted: Sun Apr 27, 2008 10:20 am
91buickman wrote:
88brain cells wrote:
.....Maybe, because the following,
oldsguy88 wrote:
........ Take the Catalytic Converter off. They restrict the flow so much they basically act as a muffler ........
is another 91buickman BS statement.
At least get the right person ........
I got it right. Read it again.
Then read this page, and in particular this post.
91buickman wrote:
........ As for me trying to trick people to think a chevy engine is a buick engine is absurd in any respect ........
Same mentality.
91buickman wrote:
........ Ive installed long tubes on a couple of cars before, and ........
Considering your record of BS posts, why should we believe this one?
91buickman wrote:
........ the exact reason..im not sure of ........
Assuming you actually made this comparison, the "placebo" effect would explain it.
PostPosted: Sun Apr 27, 2008 11:34 am
........ Does it matter or affect the exhaust to have it one way or the other? ........
Depends on the design goals, budget limits, and space constraints.
Generally mufflers are most efficient, when positioned at the farthest point from the combustion chamber.
88Coupe wrote:
........ Total displacement, compression, and cam timing, have a lot to do with it.
........ How do they relate to each other? ........
They (along with induction systems, ignition timing, etc) increase/decrease cylinder pressure and, in turn, exhaust pressures.
Tweeters and woofers = little, if anything, to do with velocity and everything to do with pressure. Not the best analogy, but it might work.
........ For instance, a typical chain saw ........
2 stroke cycle? Cam timing?
........ A lawnmower, with 900cc's of displacement ........
4 stroke cycle? Cam timing?
........ I am certain there is more to it than that ........
There is. Part of it will be in your "Header" thread.
........ could you explain?
In school, there were instructors that explained things I already knew, using a language I did not understand. If I had been able to learn that language, I could have used it to write books on the subject.
Until I do, just keep asking for clarification.
PostPosted: Sun Apr 27, 2008 12:16 pm
91buickman wrote:
........ is what i always thought they used to tune the sound ........
Tune the sound? That is funny.
They were originally designed, and sold, as a "performance" muffler. Nothing but an "echo chamber" with a couple of restrictions placed inside. they induced "turbulence" which deadened sound, but inhibited flow.
The "distinctive" sound is a byproduct of the echo chamber.
PostPosted: Sun Apr 27, 2008 12:33 pm
........ It was my subtle attempt to get the poster of the information to clarify his statement ........
Not likely. The only way to get a clarification from a BS artist, is to show him the picture.
oldsguy88 wrote:
........ Flowmaster uses Helmholtz resonators ........
Show us the Helmholtz chamber.
And see if he "gets" it.
PostPosted: Sun Apr 27, 2008 1:16 pm
aron115 wrote:
........ check engine light has been coming on and its been idling bad when it comes on ........
If this is the first time, its probably related to your missing muffler, cat, and tailpipe.
If you use a Scan tool or "paper clip" to retrieve the stored code(s) you should find a Code 13 or 44.
13 = Open oxygen sensor circuit: Make sure it's in place, and hooked up properly.
44 = Lean Exhaust: Computer/carb/dist probably cannot compensate for the missing exhaust system.
PostPosted: Sun Apr 27, 2008 1:52 pm
Images: 3
aron115 wrote:
yeah so i took the cat off and i got a much better sound. i just need to hold the exhuast up there a little better. its draggin right now and thats no good. gonna pick up another strap to put on in the back. i didnt have to time to make it go all the way back yet. still working on that. the cat was basically acting like a muffler. which is dumb. probally plugged up a tad or something. looks pretty old. i got a nice collection of cats going now. cant wait to take them in and get some money. i heard the older ones are worth a lot at the scrap yard
This thread should have been over a page and a half ago..
Oldsmobile 350 & TH350
K&N filters
Dual 600 watt amplifier
25" I-INC flatpanel display
Xbox 360 gaming system
PostPosted: Sun Apr 27, 2008 2:08 pm
DarkFox wrote:
........ This thread should have been over a page and a half ago..
Just think. If you owned the site (or even this thread) you could do something about it.
But you do not, and you cannot.
PostPosted: Sun Apr 27, 2008 5:28 pm
and this thread is more then just my car, in general what makes a car loud for the exhaust. yes i found that taking the cat off makes it louder but maybe in the future i might want to do something else, well legal..so when i put some kind of part on i know it will make it louder just not a waste of money.
PostPosted: Sun Apr 27, 2008 9:26 pm
So does that mean that a resonator is best used in front of the muffler?
I believe that analogy did work. The more fuel you have, and the more pressure you ignite it at, the bigger "bang" you get?
So to follow that analogy, the more sound amplitude you give a speaker, the harder it will fire, until you reach the threshold where it breaks.
That makes perfect sense to me. Am I missing anything?
Yes, two stroke- No cam, just ports.
Yep, 4 stroke, cam timing, while I don't know any specific numbers, it would be medium lift, short duration to keep it easy starting.
It occurs to me that I have made an "apples to oranges" comparison- It also might explain why I couldn't understand exactly what you were saying.
That's a good way of putting it- I have been in that position many times, including now.
Will do. Thanks for taking the time to clarify.
PostPosted: Sun Apr 27, 2008 9:31 pm
Unless there is something worth discussing, that follows the subject.
If you would like the thread to be over, simply don't view it.
If it were nothing but a pizzing contest, it would be a different story.
PostPosted: Thu May 01, 2008 4:45 pm
........ So does that mean that a resonator is best used in front of the muffler? ........
Assuming it's a, straight-thru, glasspack variant, yes.
Here is one of my 16" x 3" versions, made by Dynomax.
In this application, they take the "crack" out, which reduces the SPL to below 95 db.
A resonator chamber is/was often part of the OEM muffler, in place of a separate unit, as is done in the above Flowmaster.
The generic replacements on all my other cars, do not. The difference is, that anyone with normal (or slightly impaired) hearing, can easily tell they are V8s.
........ The more fuel you have ........
Make that, the more mixture. The concept of adding fuel, to an existing mixture, is what keeps 91buickman confused.
........ So to follow that analogy ........
Have you wondered why, it's called sound pressure level, instead of velocity level?
........ It occurs to me that I have made an "apples to oranges" comparison ........
Exactly.
PostPosted: Fri May 02, 2008 8:24 am
Where in this thread do you see me talking about fuel mixtures? Or would you like to bring up another thread from 2007 again?.........Another example of your B.S
PostPosted: Fri May 02, 2008 9:16 am
I had. About 2 years ago I took a really neat class on electronic music production, and the first "unit" of the class was the study of sound waves, waveforms, and what they actually are, and why we hear them like we do. It was really quite interesting.
I didn't realize, until that time, that when a speaker fires, it creates a pressure differential in "waves" that vibrate our ear drums.
It is, of course, easy for anyone to look it up on Wiki, or Howstuffworks, but to actually learn the material brings you a greater understanding.
The instructor had a large woofer, probably 20 inches or so in diameter, and it was capable of playing really low frequencies. In fact, we sat inside the first sound wave at one point, the frequency was so low.:shock:
Looks like I have sort of gone on a tangent- Oh well.
