It is currently Sun Apr 28, 2024 11:19 pm
Posted: Sun Apr 13, 2008 10:32 am |
TOC Moderator |
oldsguy88 wrote: This topic has pretty much been taken care of but I noticed that there wasn't any mention of Foam Filters. That is because the OP didn't ask, but also because the thread hijack was just being followed in the context in which it was presented. Had we been talking about the benefits of all filters, I am sure it would have come up. Quote: TRUEFOAM makes a Very good filter that flows much more than a Stock paper filter. It Filters More than K&N and the Stock filter. It does not flow quite as much as K&N but very close. Do you mean "True-Flow" or a different product? Quote: Just remember that K&N is trying to make money by selling filters. So they use marketing strategies. Our job is to look past those to the real truth and then go from there
I would assume True-Flow is too. I noticed on their site that they make a similar claim that you get "more filter" and "more flow". I am not sure that is possible. The two are inversely related (v=Q/A, where v=velocity, q=flow rate, and a=flow area), which means if you get more of one, you have to get less of the other, right?
Besides, our flow rate would be capped at whatever the carburetor or throttle body flows. In the OP's case, he has a 260, and it should have the dual jet carburetor on it, which is rated at a whopping 161cfm @ 1 Hg.
At any rate, I am not trying to bust your balls, it just doesn't make sense to me-
Regards-
Posted: Sun Apr 13, 2008 10:35 am |
TOC Moderator |
91parkave wrote: ........ The link in it is bad ........
This worked for me earlier, but I tried it today, and it wasn't there.
here is a different link, to the same test.
Posted: Sun Apr 13, 2008 3:05 pm |
TOC Member |
oldsguy88 wrote: ........ I would rather have a clean engine vs the tiny gain but with a dirty engine ........ What gain? andrewk wrote: ........ Do you mean "True-Flow" or a different product? ........ http://www.trueflow.com/premiumairfilters.phpTrue Flow wrote: Foam has been used for years in off road applications ........ ........ With True Flow’s Premium Air Filter You Get: • Outstanding dust holding capacity • The ability to wash and re-use • True Flow air filters use two stages of foam to give you the protection you need for everyday use and for extra dusty conditions!
"Off road" and "wash and re-use". Same rap as K&N.
I'm not impressed.
Posted: Mon Apr 14, 2008 4:41 am |
TOC Member |
http://www.shopatron.com/product/part_n ... 1001.0.0.0
Same size filters, I use on my Coupes.
At that time, the 468 in my Grey Coupe, used a generic 14"x3" paper filter, while the 437 in my Red Coupe had the 14"x3" K&N.
The foam filter appears to have far less surface area, compared to the conventional "pleated" designs I've always used. Less surface area exposed = Less filtration, shorter service cycle and more restriction.
I'm sure 91buickman will be along to correct my numerous errors, in this post.
Posted: Mon Apr 14, 2008 9:54 am |
TOC Moderator |
88 Coupe wrote: At that time, the 468 in my Grey Coupe, used a generic 14"x3" paper filter, while the 437 in my Red Coupe had the 14"x3" K&N. So the K&N was good for 4 tenths, and 31 CI? Quote: The foam filter appears to have far less surface area, compared to the conventional "pleated" designs I've always used. I understand the logic in the greater surface area of the pleats, but what prevents the air from just going into the peaks of the pleats, instead of being filtered by them? This is something I haven't ever quite understood-The air will take the path of least resistance, right? Quote: Less surface area exposed = Less filtration, shorter service cycle and more restriction.
Wouldn't less filter mean more flow, and thus less restriction?
Also in related news, I cleaned the K&N that is in my Lumina today... I lost the cleaning instruction sheet, so I looked it up on their site. Funny thing is, on one portion of the site, they warn you to not over-oil the filter, and on another portion, they tell you you can't over-oil it. Things that make you go hmmmm....
Regards-
Posted: Tue Apr 15, 2008 12:22 pm |
TOC Member |
andrewk wrote: So the K&N was good for 4 tenths, and 31 CI? ........ Yeah. In addition to 4 points of compression, 40° of valve duration, and .050” of valve lift. But, I digress. andrewk wrote: ........ what prevents the air from just going into the peaks of the pleats, instead of being filtered by them? ........ Air will be drawn from any part of the filter that is not restricted. andrewk wrote: ........ The air will take the path of least resistance, right? ........
Yes. But by definition, the filter is a resistance.
Posted: Wed Apr 16, 2008 7:53 pm |
TOC Moderator |
Hi Norm, all,
It took me awhile to get back to this one, too much school work to do...
Thanks for the clarification Norm, but I still have one more question:
88 Coupe wrote: andrewk wrote: ........ The air will take the path of least resistance, right? ........ Yes. But by definition, the filter is a resistance.
I understand that the filter is a resistance, but how does less filter surface area equal more resistance? I can see how it would result in a shorter service cycle, but I would think that less area would mean it is a more freely flowing filter than one that has more surface area.
Posted: Thu Apr 17, 2008 6:10 am |
TOC Member |
andrewk wrote: ........ I would think that less area would mean it is a more freely flowing filter than one that has more surface area.
Comparing the subject 14"x 3",
to a taller 14"x 5" K&N,
as shown on my 437,
What effect would the extra 2" have?
Posted: Tue Apr 22, 2008 9:58 am |
TOC Member |
oldsguy88 wrote: Have any of you ever Flow benched a K&N vs a Stock paper filter? ........ I haven't. Have you? Has K&N? Has True Flow? Has anyone? oldsguy88 wrote: ........ An increase in airflow (which a K&N and True Foam ........ ........ will provide) ........ From the fourth post, on the first page: 88 Coupe wrote: http://www.oldsconnection.com/forum/vie ... php?p=7347The K&N design, allows more airflow, by filtering it less ........ What about True Flow? http://www.trueflow.com/video/product.wvxWhich "paper filter" did they test? Was the red one a K&N, or a chinesium lookalike? oldsguy88 wrote: ........ proves that There is a potential ........ From the same post: 88 Coupe wrote: Quote: ........ performance ........ ........ Because, in theory, more air is available, it doesn't mean an engine can/will use it ........ 1. More air available = more potential. 2. More potential = useless if it's not needed. oldsguy88 wrote: ........ for an Increase of power ......... How does more potential = increased power? oldsguy88 wrote: ........ Only if the airfilter is your actual restriction ........ Does anyone here, have a restricted filter? I know I don't. From the same post: 88 Coupe wrote: ........ Yours already has more filter than it can use ........ Nuff said? oldsguy88 wrote: ........ The only way to really know is with actual data to go from ......... Again, do you have any actual data? oldsguy88 wrote: ........ Whether it be a Dyno or flowbench or strip ......... Do you mean a Time slip, or two? oldsguy88 wrote: ........ Theres really no room to argue that it will make or wont make power by having a different filter ........ To make that statement, is to advocate censorship. As long as there is someone who can learn from an exchange of ideas, there is always room for discussion. oldsguy88 wrote: ........ It is all theory until proven on paper.
On a paper timeslip?
Posted: Tue Apr 22, 2008 8:17 pm |
TOC Moderator |
oldsguy88 wrote: Have any of you ever Flow benched a K&N vs a Stock paper filter? If that plexiglass display at the local autoparts store counts, than yes. Nobody is saying that a paper filter flows better than a K&N. The debate has, and is whether or not it will make a difference. Given the OP's car, and the small carburetor that is installed on it, the answer in this case is, "There is no difference". Quote: An increase in airflow (which a K&N and True Foam [thank you for correcting me last time, My head was in the clouds]will provide) proves that There is a potential for an Increase of power.
Only if the airfilter is your actual restriction. Sure there is potential, if the engine could draw in any more air than it already is with the paper filter. Quote: The only way to really know is with actual data to go from. Whether it be a Dyno or flowbench or strip. I don't really agree with this. If you know the CFM rating of the carburetor/Throttle Body, you know how much air the engine can ingest. If that number is painfully small, like in the OP's case, you know that you are wasting money buying useless parts. Quote: Theres really no room to argue that it will make or wont make power by having a different filter. I'd agree with this, provided there is evidence supporting a presented point. EG, there is really no room to argue that a K&N air filter cover is going to yield more power output on a 2bbl 260 Olds. However, presenting a point, with data and evidence to back it up, is debating, which means there is "room to argue". Quote: It is all theory until proven on paper.
Isn't a theory an idea that hasn't been proven, on paper?
Posted: Tue Apr 22, 2008 11:36 pm |
TOC Member |
andrewk wrote: ........ if the engine could draw in any more air than it already is with the paper filter ......... Could only happen if the OEM filter was less than adequate, which is hardly the case. andrewk wrote: ........ If you know the CFM rating of the carburetor/Throttle Body, you know how much air the engine can ingest ........
Carb/TB size has little to do with it. Example is, the 800 CFM Q-jet used on my 307. Probably can't use any more than ⅓ of it.
Displacement, maximum RPM, and Volumetric efficiency (CFM = RPM x Displacement/3456 x VE), will come close to an engines actual needs.
oldsguy88
Posted: Tue Apr 22, 2008 11:56 pm |
TOC Member |
I have a Quick question. These threads I've been reading through, which have had a lot of very good information in them, seem to be a lot of (what seems like) people just trying to seem smarter than other people. Honestly, Is this true?
88 Coupe wrote: I haven't. Have you? Has K&N? Has True Flow? Has anyone? I actually have done tests. I would like to consider myself a researcher in the automotive field. I performed them with a Super Flow SF 600 Flow bench. That little box at the parts store does not give real numbers. I saw that and it made me want to try the SF 600 on similar filters to see actual data. When I performed the test I had a stock Chevy head with 1.94" intake valves. and 1.5 " ex valves. At .450 valve lift. Bolted to an Ed. Performer intake with an ed 600 cfm carb the combination was flowing 214 cfm on the intake side and 186 on the exhaust side. That was with out a filter. With a Stock Filter it was down to 179 intake and 156. With a True Foam it was at 190 cfm intake and 165 cfm ex. With the K&N it was at 194 cfm intake and 169 ex. Those are just the numbers I got and even if I did it again I would probably get different numbers. They would be close, but Im Just saying that those numbers proved to me about the real flow of the filters. Now your ideas of more airflow by less filtering is a very obvious assumption. but if you ever get the chance try their filtering capabilities for yourself. I took some awesome dirt to all them now. I laid down a white piece of paper under the same filters I just had on the flow bench. The paper had a considerable amount of dirt that fell through. The K&N had about the same, just slightly larger particles mixed in everything that fell through, and next was the True Foam. I ended up Pouring all the dirt i had on that filter. Because no matter how little or how much dirt was on it. Nothing fell through. I would like to add that the filtering capability test was pretty much as un-scientific as it gets, but Since I have no way of actually measuring what falls through in comparison to the airflow It isn't a good Argument. I just thought it was interesting to see What made it through to the naked eye. So as far as the filtering test, Thats still up for debate. It was just interesting and I thought you all might be interested. andrewk wrote: Isn't a theory an idea that hasn't been proven, on paper?
I made that statement because a lot of ignorant mentality judges power by their seat-of-their-pants dyno. I am Sure that you are aware of this though. Im skeptical until I see it on paper. IE Dyno sheets (correct ones, Not ones edited by manufactures) Time Slips (by someone who can get consistent reaction times with a consistent car) or Flow Bench data.
Posted: Wed Apr 23, 2008 12:53 am |
TOC Moderator |
88 Coupe wrote: andrewk wrote: ........ If you know the CFM rating of the carburetor/Throttle Body, you know how much air the engine can ingest ........ Carb/TB size has little to do with it. Example is, the 800 CFM Q-jet used on my 307. Probably can't use any more than ⅓ of it. Displacement, maximum RPM, and Volumetric efficiency (CFM = RPM x Displacement/3456 x VE), will come close to an engines actual needs. Norm
Thank you Norm. I thought it wasn't that easy-
