It is currently Wed Nov 18, 2026 9:23 am
 Post subject: knock sensor
PostPosted: Tue Mar 01, 2005 9:52 am
hi ...if a knock sensor gos bad will the car start or run???? thank you for your help
PostPosted: Tue Mar 01, 2005 10:17 am
Yes, it will. The knock sensor sends a signal to the ECM when the engine is uder load. the ECM uses the info from the knock sensor to either advance or retard the timing based on if spark knock is occuring or not.
this has also been discussed here: http://www.oldsconnection.com/forum/vie ... php?t=1205
PostPosted: Fri Mar 04, 2005 5:26 pm
What would the ECM presume or the knock sensor is disconnected?
